RCU Forums - View Single Post - Alpha CG..
Thread: Alpha CG..
Old 08-13-2003 | 03:54 PM
RonM
Default Alpha CG..
Sounds like it's tail-heavy now. You could probably re-trim to compensate by changing thrust angle, throw, etc, but I think you should remove your added tail-weight bit-by-bit until it flies best. (By your standards)
You did say the plane flew well where it was balanced previously, right?
Ronm
