Alpha CG.. >
Alpha CG..
Alpha CG..
Old 08-13-2003 | 03:33 PM
Default Alpha CG..
Do I have a problem??
While doin' a little maintenance, I was flippin' through the manual and came across the part referencing CG.. So for kicks, I checked the balance @ 2.75 to 3.00" from the leading edge. WAY nose heavy.. Plane flies well here, but does have a tendency to nose down when rolling. Took +/- 2.5 oz. just ahead of the leading edge of the rudder to get her balanced.
Didn't take but a click or two down for level flight @ full throttle, but at reduced throttle, dives, and requires retrim up to maintain level.. Adding throttle, plane climbs. Reduce throttle, dives. Also on landing, has a tendency to "porpoise" right b4 touch down. Coming in a little "hot" is a bit worse..
Did I make sense??
Is a little down thrust needed, or just put it back the way it was...
After trimmed to level flight, plane flies well, with no tendency to drop the nose during a roll..
Thanks for looking!!!
Old 08-13-2003 | 03:54 PM
Default Alpha CG..
Sounds like it's tail-heavy now. You could probably re-trim to compensate by changing thrust angle, throw, etc, but I think you should remove your added tail-weight bit-by-bit until it flies best. (By your standards)
You did say the plane flew well where it was balanced previously, right?
Ronm
Old 08-13-2003 | 04:38 PM
Default Alpha CG..
Correct...
