RE: DMD issues
Try the Kiss principle..
Check your tank and TX Battery, TX radio & antenna, crystals, Y-connector, Receiver & wires, communication cable (Examine it carefully) and verify all the connections are tight and wires are good with a magnafying glass. Then run the set-up and check off each step as you go. Have you done any work on the tank recently that may have had a side effect?
Bob
