RCU Forums - View Single Post - Brisson 3.2 Carb
Old 05-14-2011 | 02:30 PM
Truckracer
My Feedback: (19)
Default RE: Brisson 3.2 Carb
ORIGINAL: Stick2000
If the carb was 14.95 I would have ordered one before, however the throttle plate has not worn the carb body!
Just though I ask to see if anyone else may have had this problem and new of a fix other than replacing the carb.
If this thread doen't agree with your way of thinking , please don't post!
Stick2K
Sir, your original post requested a source for a replacement carb. You didn't ask for assistance about rebuilding your carb or how to tell if it was bad, etc. You only asked for a replacement source.
I responded with several sources for both the WT-76 which is the most common carb on your engine and later when you came back with a different carb number I responded with sources for that carb. Among the links posted were sources for both carbs at under $15.00 USD. There were other sources also posted at a higher price.
The first Eb-y source I quoted for the WT-76 removed the $14.95 listing shortly after my post .... I have no control over that but I assure you it was there there when I made my first post. The link in post #5 is still current (as this is being written) for the other carb at under $15.
Sorry I ever got involved with this post. I'm outa here on this one as I don't think you really know what you want and don't appreciate info when it is given to you.
