RCU Forums - View Single Post - checking for spark
Old 05-14-2011 | 04:20 PM
skysfallin
My Feedback: (10)
Default RE: checking for spark
When checking the spark make sure you have a known good plug in the socket. You don't have to ground it to the engine because stainless braid on the plug wire is your return ground. Just make sure the plug is in the socket and there is a good tight connection to the plug base. Some ignition boxes will be damaged if the engine is turned over with no plug in the socket.
