<![if gte mso 9]><xml><w:WordDocument><w:View>Normal</w:View><w:Zoom>0</w:Zoom><w
oNotOptimizeForBrowser /></w:WordDocument></xml><![endif]><![if gte mso 9]><xml><o:shapedefaults v:ext="edit" spidmax="1026" /></xml><![endif]><![if gte mso 9]><xml><o:shapelayout v:ext="edit"><o:idmap v:ext="edit" data="1" /></o:shapelayout></xml><![endif]><p style="text-align: justify;" class="MsoNormal"><span style="font-family: Verdana;">Hi All,</span></p><p style="text-align: justify;" class="MsoNormal"><span style="font-family: Verdana;">I am thinking about moving up to larger scale planes and have been doing a little reading on the web.<span style=""> </span>I have a few questions about what I have found and hope you can help.<span style=""> </span>In particular, when it comes to having two or servos controlling one control surface.<span style=""> </span>For instance, a set-up which required two servos controlling the elevators, two servos controlling the rudder, and say four on the ailerons with two each side.<span style=""> </span>I understand the purpose of this is to provide enough torque to move and hold the control surface in question.<span style="">
</span></span><span style="font-family: Verdana;">My question about this type arrangement is how are the servos wired up together, and how are they synchronized?<span style=""> </span>I did see a mention of a servo synchronizer but could not find any on the web, so I think maybe I misunderstood what I was reading.<span style=""> </span>The question of power also comes to mind and is it necessary to have larger power packs to deal with this?<span style=""> </span>How would you guys go about this kind of set-up, and what would you use to achieve it?</span>
<span style="font-family: Verdana;">Your help in understanding how this sort of set-up is done would be much appreciated.</span></p><p style="text-align: justify;" class="MsoNormal"><span style="font-family: Verdana;">Regards,</span></p><p style="text-align: justify;" class="MsoNormal"><span style="font-family: Verdana;">John
</span></p>
