RCU Forums - View Single Post - Large Scale Setup
Old 05-16-2011 | 05:29 AM
SpudB
Default RE: Large Scale Setup
<xml><span style="font-family: Verdana;">Hi All,
</span><span style="font-family: Verdana;">Thanks for you comments on my post which are most welcome.<span style=""> </span>Huck119 I have registered for the Giant Scale forum and will also be visiting it in the future.<span style=""> </span>Thanks for the mention.<span style=""> </span>I have also registered for Smart Fly as mentioned by Laird SS.</span>
<span style="font-family: Verdana;">I have been looking at one of </span><span style="font-family: Verdana; font-style: normal;">Hostetler's Cessna&rsquo;s to get started and to use as a platform for learning how the set-up is done and about the items available for larger scale models.<span style=""> </span>Most of what I have done in the past is only small scale up to about 75 in. span.<span style=""> </span>Not much is required for this type of model regardless of it being scale or aerobatic.<span style=""> </span>But, as you all know, it&rsquo;s a little different when you move up to large scale and gas engines etc.<span style=""> </span>Anyway, I was thinking that one of these Cessna&rsquo;s would be a good start in large scale.</span>
<span style="font-family: Verdana; font-style: normal;">That&rsquo;s for your comments Steve and the information about what is needed.<span style=""> </span>I will now start reading up on each of the items you mentioned and try to find out more.<span style=""> </span>Thanks again to all for your help.</span>
<span style="font-family: Verdana; font-style: normal;">Regards,</span></xml><![endif]><p class="MsoNormal"><span style="font-family: Verdana; font-style: normal;">John
</span>
</p>
