RE: wingtubes bending ...
Another option: go to home depot or equivalent and get the closes diameter wood dowel (bigger than the ID of the tube). Put in oven for about 10 minutes to dry. It wll likely now slip inside the wing tube or require light sanding. Insert it and you are done. It will slowly absorb moisture and get a very tight fit with the wing tube.
