RCU Forums - View Single Post - Throttle connections/sensor mounts?
Old 08-16-2003 | 07:27 PM
Ronbo
My Feedback: (12)
Default Throttle connections/sensor mounts?
would it need to be THAT big for just the small sensor? i was thinking of a simple bracket that bolted to the thin fin just forward of where u say drill and tap....it looks strong enough, plus i dont think the bracket needs to be that large?
also, would the end of the sensor work, or do i lay it flat? the end of the sensor has a bevel, and the bevel will trigger the igntion. i tried it, 'seems' to work if i can make the bracket work..
