RCU Forums - View Single Post - Adjusting split elevators?
Old 05-21-2011 | 08:45 AM
Mustangman40
Default RE: Adjusting split elevators?
ORIGINAL: scale only 4 me
Much easier to just take a straight edge, lay it across the stab so it extends out over the elevators,, then just match up both sides
good luck
so4m,
It has an airfoil on top and bottom, it's not flat.. I guess I could lay a ruler so that it's tight to the TE of the stab and then adjust them both the same. I would think that would give it down elev. trim, but if both are the same i can trim it up to neutral..
