RE: New O.S. 46AX
You probably just don't have it primed right. For hand starting, you need a fairly wet prime. You can check it by priming the engine, then slowly turning the prop through the compression with your hand holding it firmly. If you feel a small kick at TDC, then you're primed right. If not, prime it some more.
