RCU Forums - View Single Post - Nose down on full power Help Required
Old 05-22-2011 | 04:45 AM
bogbeagle
Default RE: Nose down on full power Help Required
You can't really solve this by altering the wing' geometry, though some engine upthrust may ameliorate the tendency.
The reason that you can't solve this is that it is not a "problem" ... it's merely a trait of that airframe layout. That is, it's perfectly normal. Some full-sized aircraft, with high-mounted engines, behave in the same way. They pitch down with power.
So, you can try some engine upthrust ... try 5 degrees or so.
You can mix in some elevator trim with throttle, such that increased power coincides with a little "up" trim.
You can just get used to re-trimming for each power setting.
