RE: Webra .32 Plug Choice
Idle bars are generally not needed with modern engines. The idea was to stop fuel from dousing the element, and it is generally considered that this was more a problem with engines of older design, pre-Schneurle porting. They are sometimes used in inverted installations to improve idle reliability, but I don't have personal experience to say yea or nay on that one.
One thing I noted in the advice columns of yore, was to make sure you use idle bar plugs where the idle bar is machined into the body of the plug, versus welded-on as those have the potential to come loose and you can imagine the havoc. No idea whose are and whose are not of this construction, I have not used an idle bar plug in a donkey's age.
MJD
