RCU Forums - View Single Post - need name of plane
Old 05-26-2011 | 07:27 PM
doxilia's Avatar
doxilia
Default RE: need name of plane
Yea, that's what I was thinking (stab is close) but the nose is off (engine was inverted and had glass cowl - at least the MK Skymaster). Also wing saddle is off. The 60 size had a partial wing saddle with a flat spot in the wing LE where the wing met the fuse. LE of wing extended on either side of the fuse side.
Also, the fin is not right. The fin tip was much thinner. This fin tip is more akin to the Mach 1 - not that the rest of the plane has anything to do with an M1.
What about a Cosmos with a wood canopy? Stab would be off though. The fuse top canopy area looks very much like a Skymaster (which also had a glass deck to cover the pipe).
David.
