RCU Forums - View Single Post - Can I charge both at the same time
Old 05-28-2011 | 05:00 PM
FlyingGatsby
Default RE: Can I charge both at the same time
I can't see the plane vibrate, so that means it doesn't spread through the plane too much. But you can notice the vibration the most on the engine, and it smoothen out a lot as the rpm gets higher, enough that you can't see the vibration anymore.
