RCU Forums - View Single Post - Regulator Switch - Beat this
Old 05-29-2011 | 06:58 AM
  #41
bigplumbs
Banned
Default RE: Regulator Switch - Beat this
ORIGINAL: LGM Graphix
Problem is, when its cheap, one unit may work just as well as an expensive unit and the next ten might fail. I liken it to heart surgery, suppose there are two doctors that from the outside their credentials look the same. The difference is the first dr went to medical school, did his residency at the mayo clinic and has performed thousands of successful operations. The chinese dr watched reruns of doogie howser md, photocopied diloma's, and tried to operate on a goat and got lucky. Both dr's can show you the same credentials but only one worked for them. I don't think i'd go with the cheaper dr.
Each to there own I surpose.................. Interesting however . So if two things are the same and as good as each other and one is £bi10 and the other is £70 you would buy the £70 one............... Does that make sense or is it that you are just loaded
Dennis
Hang on a mo............ Surely you dont think a regulator switch is comparable to heart surgery do you............ Get real
