RCU Forums - View Single Post - Regulator Switch - Beat this
Old 05-29-2011 | 08:28 AM
  #43
bigplumbs
Banned
Default RE: Regulator Switch - Beat this
ORIGINAL: LGM Graphix
ORIGINAL: bigplumbs
Problem is, when its cheap, one unit may work just as well as an expensive unit and the next ten might fail. I liken it to heart surgery, suppose there are two doctors that from the outside their credentials look the same. The difference is the first dr went to medical school, did his residency at the mayo clinic and has performed thousands of successful operations. The chinese dr watched reruns of doogie howser md, photocopied diloma's, and tried to operate on a goat and got lucky. Both dr's can show you the same credentials but only one worked for them. I don't think i'd go with the cheaper dr.
Each to there own I surpose.................. Interesting however . So if two things are the same and as good as each other and one is £bi10 and the other is £70 you would buy the £70 one............... Does that make sense or is it that you are just loaded
Dennis
Hang on a mo............ Surely you dont think a regular switch is comparable to heart surgery do you............ Get real
A little thick aren't we......
What I said was basically, anyone can copy something and put on a good facade to sell themselves or a product. Might even get lucky a few times, but the cheap copied crap will always be that, cheap copied crap. When something goes wrong in a copied product, they won't have a clue how to deal with it or fix it. A switch is the heart of your airplane, shut that switch off and the nerve center, brain, and all muscle control flies out the window. Yes, even the best systems can fail, just like the healthiest people in the world can have a heart attack, but in the end, I want to have my best chances, and that means the products that are designed, produced, and supported by one manufacture, not copied by some goat in dr's clothing.
So, as an analogy, yes, I think it's very comparable. In life seriousness of course not, but I would have hoped that people would be able to see it as an analogy, not an absolute literal word.....
Long excuse which dont change the fact that you tried to enforce your point by making a comparison that was way at the other end of the scale. A persons heart and a switch in a toy plane................ Give me strength
As with so many of your posts lots of words dont make it right...... Think more type less
Keep that mask on when you are spraying I think you breathed in too much
Dennis
