RCU Forums - View Single Post - Issues running on grass
Old 05-29-2011 | 08:49 AM
yellowshaker's Avatar
yellowshaker
Default RE: Issues running on grass
Is it possible that the track tension is not correct? Check that none of the sprocket bolts came loose. I would also check that the gearboxes are not binding up under stress. Perhaps a bushing or bearing problem causing binding when the tank is trying to make a turn.
