Issues running on grass
Old 05-29-2011 | 01:36 AM
Default Issues running on grass
Hi, Im having problems with one of my king tigers its never previously had issues running on grass but recently It refuses to perform neutral turns with one track locked, the motors just stall out. This tank uses impact 3:1 boxes and kenny kong metal tracks. Ive tried using different sets of motors (all broken in) and not luck. Strangly my other KT with uses impact metal tracks and gear boxes runs just fine on the grass! If anyone has any ideas Id be greatful!
Old 05-29-2011 | 04:05 AM
Default RE: Issues running on grass
Are you sure the battery is good? If it doesn't hold a full charge then it wouldn't power the tank on anything other thena smooth surface. Try swapping batteries from the good tank and see what happens.
Jim
Old 05-29-2011 | 04:37 AM
Hey out of desparation ive tried using the same transmitter,rx , battery , mf and dmd the only variable are the tus (which ive taken out tested and the ones on the issue tank are actually smoother) the tracks , idlers and suspension!
Old 05-29-2011 | 06:32 AM
karel47's Avatar
is it a tamiya or a heng long or matorro
i don't have isseus with my king tigers they all have the original plastic tracks of tamiya running good everywere, yes could be the batterypower ...................
Old 05-29-2011 | 08:44 AM
Its a tamiya, and as I have said its definatly not the battery, my other KT runs fine with the same battery and I have tired all the different batterys I have an no luck
Old 05-29-2011 | 08:49 AM
yellowshaker's Avatar
Is it possible that the track tension is not correct? Check that none of the sprocket bolts came loose. I would also check that the gearboxes are not binding up under stress. Perhaps a bushing or bearing problem causing binding when the tank is trying to make a turn.
Old 05-29-2011 | 10:00 AM
You by chance did not upgrade your sprockets to Impact sprockets did you .
Jimmy
Old 05-29-2011 | 10:14 AM
Using the tamiya sprokets which work fine on the other tank!
Old 05-29-2011 | 08:01 PM
First, check that nothing is binding in the drive system. Put him up on blocks, and run the tracks, making sure they are both the same speed. This is adjustable with the DMD system. If they are not running the same no load speed, check for binding in either side of the drive train system. If all is the same, put him on the floor, run him, and see if he runs straight and true with the steering stick in neutral. If not, follow the instructions to reset the DMD/TO system, and test again. If still pulling to one side or another, then adjust the rudder pop on the DMD/TO. If still having a problem, check wheels and idlers for a bind.
Also, are the transmissions making any unusual noises?
Old 05-31-2011 | 08:52 AM
heavyaslead's Avatar
Agree with Bob here,
The DMD has an overload built in that when current exceeds a certain point (overheat), the FET outputs shut off until load is removed.
If the track pins are too stiff, preventing easy flexing of the track links (as in gluing the pins), there could be extra resistance for a few links that do not pivot on the pin completely.
Old 05-31-2011 | 09:15 AM
Thanks for the tips guys! Ive overcame the problem by rebuilding my tamiya boxes I had with the 3:1 reductors and adding shaft supports, working like a champ now!
