ORIGINAL: pimmnz
If you have the wing then you really don't need any 'build instructions', just copy any of the well known models of the time, it was all pretty generic. If you don't have the wing, then you will need a plan from the kit, and be prepared to do a bit of rib extrapolation, but 99% of what you need will be done/drawn for you. If you still can't complete the model, then perhaps you should consider passing it along to someone who can. It is a nice airplane, and flies just like a classic should, and deserves a good home.
Evan, WB #12.
Hi Evan
I have a wing from a dirty birdy that i have to make fit which is not to hard just have to fill in the wing saddle abit as airfoil is different, and was just going to see if it needed any incidence in the wing .
thanks
Matt
