RE: DLE 30 Prop Mount
The hex on this shaft is down below the prop thrust washer . I do not have a socket long enough to engulf the entire shaft and still grab the hex.
Also there is very little room between the hex and wall of the hole in which it sits . The wall of the socket would need to be very very thin as well.
I do not see how heat can be applied to it it is down deep in the crank shaft.
Thank you .
