RCU Forums - View Single Post - DLE 30 Prop Mount
Old 05-30-2011 | 02:33 PM
jedijody's Avatar
jedijody
Default RE: DLE 30 Prop Mount
Did you not see the link to the manual on the adapter page, it explaines how to remove the pilot shaft. If you don't have a socket deep enough just cut the pilot shaft off as close as you can to the hub, then remove what's left with a regular socketthen cut it again the way the instructions show.
http://www.valleyviewrc.com/estore/m...structions.pdf
