RE: Adding weight for CG
Hi _brad_
Having built many kits I eventually learned that the correct location of the CG must be kept in mind VERY EARLY in the build. I tape or tie everything near its location and make adjustments very early, and repeat this as needed. My aim is to never add balancing weight, but if needed, I add the weight. I have used the heavy brass nose cone in place of the standard nut, and never saw a problem.
