RCU Forums - View Single Post - Adding weight for CG
Old 06-02-2011 | 06:27 AM
Charlie P.'s Avatar
Charlie P.
Default RE: Adding weight for CG
ORIGINAL: bkdavy
If you have to add nose weight, you're not using a big enough engine!
Brad
Irepresent that remark! Iusually have to add tail weight.
I'd prefer not to add 8 oz to a .60 size model, but you do what you gotta do. Get the engine and battery as far forward as possible. Shiftingthe receiver doesn't help as much as it used to.
A Harry Higley nose hub will putweight as far forward as possble so you need less.
