RCU Forums - View Single Post - Adding weight for CG
Old 06-02-2011 | 07:52 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: Adding weight for CG
ORIGINAL: _brad_
Any suggestions will be appreciated.
Adding weight is not a Sin - Nor is moving things around a Sin
When ones chooses to add weight here is a simple safe way to get the weight (lead shot) all the way forward where it will do the most good without the disadvantages of hanging it on the crank shaft.
When one chooses to move things around here is a simple safe way to do the same with the battery which will do the most good.
John
ID:	1618168   Click image for larger version
ID:	1618169   Click image for larger version
ID:	1618170   Click image for larger version
