Amount of elevon reflex in a Roo or Rookie???
I purchased a Rookie----All of the throws are listed in the instruction manual except for the amount of up reflex needed in the elevons when neutral. I want to know how much reflex you guys are using and if you know, the CG of your model. The Rookie and Roo should use about the same amount of reflex respectively.
TIA!!!!
Kevin
