RCU Forums - View Single Post - Parkzone Scaler: Good Beginner?
Old 06-06-2011 | 05:20 AM
CGRetired's Avatar
CGRetired
Default RE: Parkzone Scaler: Good Beginner?
Ahh... no. Any bi-plane is not a beginners aircraft. And, adding a camera, any weight, to an electric powered aircraft requires re-thinking of the power needed to fly it, if it will fly at all with the added weight of a camera.. all depending, of course, what the weight of the camera is, and how the plane is powered, and if the structure of the aircraft will take the added weight.
I know enough about electrics to tell you that a bi-plane is not a good electric nor glow powered trainer, for that matter. Many will come in and make recommendations as to what would be a good electric trainer, so my point will be to tell you that.
With electric power, a lot has to be taken into consideration before making any changes in the power of the plane, mainly power to weight.. watts per pound in other words. There are guidelines to that, and before you can do anything like adding a camera, the entire weight picture has to be examined so that you know what motor, esc, and battery power to use so that it will fly.
CGr.
