 Parkzone Scaler: Good Beginner? >
Old 06-06-2011 | 05:05 AM
Default Parkzone Scaler: Good Beginner?
Hey I wanted to get into planes (already into cars), but would a WWI Bi-Plane ARTF be a good beginner for me? I will buy my own radio system. I plan to fly in my neighborhood and in grassy fields, and would like to eventually mount a FPV camera on it. Is this plane right for me?
Old 06-06-2011 | 05:20 AM
CGRetired's Avatar
Default RE: Parkzone Scaler: Good Beginner?
Ahh... no. Any bi-plane is not a beginners aircraft. And, adding a camera, any weight, to an electric powered aircraft requires re-thinking of the power needed to fly it, if it will fly at all with the added weight of a camera.. all depending, of course, what the weight of the camera is, and how the plane is powered, and if the structure of the aircraft will take the added weight.
I know enough about electrics to tell you that a bi-plane is not a good electric nor glow powered trainer, for that matter. Many will come in and make recommendations as to what would be a good electric trainer, so my point will be to tell you that.
With electric power, a lot has to be taken into consideration before making any changes in the power of the plane, mainly power to weight.. watts per pound in other words. There are guidelines to that, and before you can do anything like adding a camera, the entire weight picture has to be examined so that you know what motor, esc, and battery power to use so that it will fly.
CGr.
Old 06-06-2011 | 05:23 AM
CGRetired's Avatar
Sorry, but when you said your own neighborhood, in a grassy field, I just assumed electric. You may be looking at glow. Either way, a bi-plane is not a good trainer. If you want to select a good trainer in the glow powered category, go to the top of the first page of the Beginners Forum and look over the list of trainers that are there. There are a lot of planes to select from and they are all great trainers.
And, don't plan on using your car radio.. you have to get a good four channel radio (at least four channels.. throttle, aileron, rudder, elevator) or more.
CGr.
Old 06-06-2011 | 10:22 AM
i will buy my won 6 channel rx/tx setup. how about this one for a beginner then:www.parkzone.com/Products/Default.aspx? i want something that isn't too beguinnerish, something i can keep for years and not spend much on cuz i mainly wanna focus on cars.
ORIGINAL: CGRetired
CGr.
Old 06-06-2011 | 02:16 PM
CGRetired's Avatar
Well, that's not a neighborhood-grassy field aircraft either. And, in my opinion, not for a beginner.
I'm surprised no one has given you some suggestions for a good electric beginner.
Old 06-06-2011 | 02:23 PM
Banned
you are going to want to start out with a high wing trainer. how big is the neighborhood/grassy field you are planning on flying in?
Old 06-06-2011 | 02:34 PM
well this one seems more beginner based: www.parkzone.com/Products/Default.aspx. but will i be able to put a larger BL motor in it and a bigger lipo?
Old 06-06-2011 | 02:38 PM
Banned
not sure on that. but if you look at the transmitter on that plane its a little ehh. what about considering one of these? since you want the bigger scale ones then maybe the sport and select scale? http://flyzoneplanes.com/airplanes.html
Old 06-06-2011 | 02:44 PM
i like the SkyFly Max alot, and its a good price. thanks. but do you know if that thing will hold up to a larger motor and ESC for more speed?
Old 06-06-2011 | 02:49 PM
Banned
no sorry idk that. maybe the experienced guys will know. im just thinking about planes too right now
Old 06-06-2011 | 02:53 PM
Banned
no sorry idk if that would hold up. gotta leave that up to the experienced plank flyers im thinking about a plane too right now, so i just have a limited amount of knowledge on them for now.
Old 06-06-2011 | 03:01 PM
CGRetired's Avatar
Would you mind, for the sake of most of us that don't comprehend the text lingo... please use real words.
CGr.
Old 06-06-2011 | 03:04 PM
Banned
 then let me rephrase my lingo. Idk- I don't know.
Old 06-06-2011 | 03:13 PM
so is the SkyFly Max a decent beginner plane? and would it be able to hold up to higher top speed due to a larger motor/ESC/baterry? thanks for the help CGr.
ORIGINAL: CGRetired
CGr.
CGRetired's Avatar
Thank you, but I thought you would get the idea the first time I asked.
Keep in mind that most of the folks that are trying to help you out here are much older than you and may not understand all those abbreviations. I know I certainly don't, and don't have the time to learn.
CGr.
Old 06-06-2011 | 03:19 PM
CGRetired's Avatar
The Skyfly Max has been discussed many times here, and, yes, of all the ones mentioned in this thread, that's the best one to learn with.
CGr.
Old 06-06-2011 | 03:30 PM
cool. looks like it will be my plane of choice.
Old 06-06-2011 | 05:26 PM
what about this one? javascript:mox();
Old 06-06-2011 | 09:44 PM
tryingagain's Avatar
http://secure.hobbyzone.com/HBZ7300.html
http://secure.hobbyzone.com/HBZ4800.html
Try looking at either of these. The size of your "field" would dictate the one you choose. The larger version also has floats available for it. Both all foam, easy fix, good stable starting points. A friend of mine started with the larger version and taught himself to fly.
Good luck with your search.
I do firmly believe the best way however is a nice 40 size trainer, an RC club and an instructor. I realise however that is not always practical or desired.
Whatever you decide enjoy!
Cheers
Gord
Old 06-07-2011 | 04:14 AM
i do like the Mini Super Club, but for 50 bucks more i can get the SkyFly Max which has alot more features. this will be my second option though for sure!
ORIGINAL: tryingagain
Cheers
Gord
Old 06-07-2011 | 04:56 AM
Moderator
It would be good to understand before getting started that any of these small planes are going to be sensitive to wind, and that you'll need more space than you initially think you do. Space = time to think! If you have a nice open field to fly at, the standard Super Cub is your best bet for getting in the air fast. And it's big enough to carry a keychain camera without any modifications. Whatever you choose, welcome to RC flying. If you will connect with an instructor for at least your first day of flying, it will save you hours upon hours of frustration. If you ever get to Fort Worth, I'd be willing to help you, but I believe there is an RC flying club in Tyler too.
Old 06-07-2011 | 08:10 AM
Parkzone T-28. This is about as stable as it gets. If you have a little aileron experience your covered. I started flying with the Hobbyzone Mini super cub and it thought me how to fly but I got bored very VERY quickly with it. I have the micro T28 and was about to get the larger version but think I will pass for the P47 instead, I would grab Phoenix and the Larger or Micro T28 and have fun. <div>
</div><div>
</div>
Old 06-07-2011 | 09:50 AM
yeah my LHS has a flying club.
ORIGINAL: jester_s1
Old 06-08-2011 | 05:11 AM
ATVAlliance's Avatar
I just built one of these, and while its definitely not a trainer, it can be flown by a novice with rates low and a lot of expo.  But I suggest LOTS of sim time first to get orientation down.
http://www.nitroplanes.com/91a-3dhawk-arf.html
Only thing needed to finish is some glue (I used hot glue and CA) and a RX/TX.
Really amazed at how well this plane flies for 60 bucks.  For that price you can buy 2 or 3 of them and by the time you build the 3rd one you should be good enough to never crash it.
However, when you do crash...its easy to fix with some hot glue here and there. </p>
