RCU Forums - View Single Post - Two servo ailerons
Old 06-06-2011 | 02:04 PM
EscapeFlyer's Avatar
EscapeFlyer
Default RE: Two servo ailerons
ORIGINAL: WhiteRook
A servo for each a ron is a bit heaver , but a lot less slop, A LOT.
This is simply not true when installed properly.
And... nobody is required to approach an aileron install in any other manner than safely. Belcranks work just fine, and without slop. So does the aileron rod method. Both of these can use 2 servos as well, btw, and you don't have to add extra weight outboard in the wing. From this knowledge, belcranks and aileron rods make more sense, actually.
Brian
