 Two servo ailerons >
Two servo ailerons
Two servo ailerons
Old 06-06-2011 | 01:06 PM
sensei's Avatar
Default RE: Two servo ailerons
ORIGINAL: BarracudaHockey
With the cost of a servo, and the capabilities of even a modest radio, I see no reason whatsoever NOT to put one servo on each aileron.
My point exactly.
Bob
Old 06-06-2011 | 01:17 PM
My Feedback: (38)
A servo for each a ron is a bit heaver , but a lot less slop, A LOT.
Old 06-06-2011 | 02:04 PM
EscapeFlyer's Avatar
ORIGINAL: WhiteRook
This is simply not true when installed properly.
And... nobody is required to approach an aileron install in any other manner than safely. Belcranks work just fine, and without slop. So does the aileron rod method. Both of these can use 2 servos as well, btw, and you don't have to add extra weight outboard in the wing. From this knowledge, belcranks and aileron rods make more sense, actually.
Brian
Old 06-06-2011 | 03:24 PM
The bell crank method works great. Allthough to prevent blow back, and gear striping I would use a higher torque metal gear servo. It never hurts to over do it.
Old 06-06-2011 | 04:26 PM
ovationdave's Avatar
My Feedback: (16)
ORIGINAL: Ilikebipes
ORIGINAL: WhiteRook
Brian
I would have to agree that a bellcrank can be set up to be very efficient. I had one in a Don Muddiman "Flying Machine" and used a single servo with a "line drive" servo horn that was sweet. It worked really well, and doesn't move the aileron torque rod up or down with the rotation of the servo horn. I have also used single servo method many times with good results. But as many others have mentioned, I think the dual-servooption is thebest for flexability, ease of installation, almost idiot-proof slop reduction, and overall is just the best option available in my opinion. And redundancy is a good thing,I knowI had no problem landing my giant super sportster when one aileron horn broke last year. With one aileron working, I hardly noticed (except for the aileron flutter on one side!) But when you get down to it, they all work, and can all work perfectly fine for a plane like the chipmunk.
Dave
Old 06-06-2011 | 04:58 PM
  #31
wow, lots of good discussion here, things I've never thought about. I was about to rip out a good looking bell crank set up on a 1/6 Pica Waco for two outboard aileron servos but now I don't know. Only thing is they are old and plastic. If I can replace the plastic with something like above I may try them with a stronger servo or two. Thanks for all the discussion.
Jim
Old 06-06-2011 | 05:03 PM
  #32
does CG even sell anything any more ?
Old 06-06-2011 | 05:26 PM
  #33
My Feedback: (-1)
ORIGINAL: zacharyR
Yes/no. Cg was bought out by Lanier then Lanier was bought out by great planes. GP pretty much killed off most of the kits but the Chip and Cub is still alive and well.
Old 06-06-2011 | 05:29 PM
  #34
sensei's Avatar
ORIGINAL: ovationdave
ORIGINAL: WhiteRook
Brian
I would have to agree that a bellcrank can be set up to be very efficient. I had one in a Don Muddiman ''Flying Machine'' and used a single servo with a ''line drive'' servo horn that was sweet. It worked really well, and doesn't move the aileron torque rod up or down with the rotation of the servo horn. I have also used single servo method many times with good results. But as many others have mentioned, I think the dual-servo option is the best for flexability, ease of installation, almost idiot-proof slop reduction, and overall is just the best option available in my opinion. And redundancy is a good thing, I know I had no problem landing my giant super sportster when one aileron horn broke last year. With one aileron working, I hardly noticed (except for the aileron flutter on one side!) But when you get down to it, they all work, and can all work perfectly fine for a plane like the chipmunk.
Dave
Yes, a bellcrank can be setup to work just perfect with no problems if you are willing to really go the distance, but why in the world would you do this on an aerobatic aircraft when you can go direct link to a number of fantastic servos and linkages available today. OK, so this kit was designed for a single servo on the ailerons, old school and it worked alright with those old servos and those old engines from the past... Today we all have the option to make thing work fantastic with the available electronics, power plants, and all the gadgets to go with everything. I have also been building and flying for over 40 years, so I remember all those kits and yes, I miss them, but the engines and am radios... I am happy to say they are gone!!! Yes, they got us were we are today, but it really is long past time to move forward. Personally I like changes for the better.
Bob
Old 06-06-2011 | 06:21 PM
  #35
Gene, sit down, this is going to hurt. Neither the cub or the Chipmunk is avaiable at tower any longer on the Tower site. In fact just like the Lanier line, the Goldberg line isgone. If you do a brand search, not a single plane shows under Goldberg, just a few misc parts and not many of them. The Goldberg site is still up but not the old one. They state thatthey don't sell direct anylonger, go to your LHS. I'm guessing if Tower doesn't sell it, it's not avaiale unless it is "Old Stock" at a LHS.
Don
ORIGINAL: Gray Beard
ORIGINAL: zacharyR
Old 06-06-2011 | 07:18 PM
  #36
Just checked Advantage Hobby and they have both in stock acording to their web site.
Don
Old 06-06-2011 | 07:22 PM
  #37
My Feedback: (21)
In reality either system will work. You can use small light weight digital servos and not gain any weight. Bellcranks work and are time proven, but generally can't be adjusted easily once the covering is on. I owned this exact plane. If you use bellcranks I recommend using ball links for smooth non wear durability. Best of luck! Mike
Old 06-06-2011 | 08:06 PM
  #38
I am really impressed with all of the great ideas!  I ordered the Chipmunk last weekend from Tower and I feel like a young kid just before Christmas!<div>As suggested, I am going to buy a 4 channel arf trainer and get comfortable with it before I take the Chipmunk up. It will probably take allot longer to build than I am thinking so it probably wont build up too much dust.</div><div>
</div><div>One more question on the aileron servos...</div><div>I like the idea, ease and redundancy of two servos but if I mount them out in the wing to avoid a long control arm, that seems sort of anti aerobatic, if I mount them next to each other in the wing root, it still has two long control arms. Am I over thinking this?</div><div>
</div><div>Thanks again,</div><div>Mike</div>
Old 06-06-2011 | 08:51 PM
  #39
oskartek's Avatar
Another point that I have not seen in this thread is that if your transmitter has flaperon mixing you are going to
need dual servos if you wish to use that function.
Happy flying, Oscar
Old 06-07-2011 | 03:00 AM
  #40
sensei's Avatar
ORIGINAL: atomic monkey
Yes, you are way over thinking this, just place your servos out from the root of the ailerons around 38-40% of the span and you will be set.
Bob
Old 06-07-2011 | 04:46 AM
  #41
BarracudaHockey's Avatar
What do you mean by "anti aerobatic" ?
You'd be hard pressed to find any kind of aerobatic aircraft manufactured today without that setup.
Old 06-07-2011 | 01:30 PM
  #42
who sells good bell crank set ups? I'd like to try a pair.
Old 06-07-2011 | 02:30 PM
  #43
Anti aerobatic might be a little overkill! And now thinking about it, an extra 37 grams out in the wings while they are under load is probably nothing. <div>The funny thing is, I am getting all serious about this airplane and sweating each detail and I have never even flown a four channel plane much less the aerobatics that I imagine I will be doing with it one day!!!</div>
Old 06-07-2011 | 02:44 PM
  #44
sensei's Avatar
You have already learned to fly pitch and yaw, now your just adding roll and power, you will do just fine.
Bob
Old 06-07-2011 | 05:39 PM
  #45
tower still has the goldberg cub &amp; chipmunk, but it is listed under great planes kit section
