RE: Two servo ailerons
In reality either system will work. You can use small light weight digital servos and not gain any weight. Bellcranks work and are time proven, but generally can't be adjusted easily once the covering is on. I owned this exact plane. If you use bellcranks I recommend using ball links for smooth non wear durability. Best of luck! Mike
