ORIGINAL: bbrown2828
ok well i checked battery and it is good I have 6 volts coming out of the regulator. I checked the Ingition it has spark so tomorrow I will start it up with the opto kill bypassed and see if that might be my problem
That would have been helpful to know.
Anytime you are running addons always start by process of elimination. Bypass each to see if it interferes. I will say in the past i have had instances where the opto kill switch was causing the problem.
Anytime if you are having problems post up any addons that you may have added. Cause the addons can potentially be the culprit.
