RCU Forums - View Single Post - Recalcitrant 160
Old 06-07-2011 | 12:33 PM
Mastertech's Avatar
Mastertech
My Feedback: (31)
Default RE: Recalcitrant 160
Yes, my 1.60 can be a bear to start first thing.
What I do is never run the engine dry unless I'm not going to fly it for several months. I never "Prime" it either, thats a great way to flood it. Then you really have a problem on your hands.
I start it the first start of the day like you would any other engine. Low idle, glow on, spin it.
It takes a bit more spinning however on the cold start. Once this is accomplished it starts very easily the rest of the day. If you've not flown it in a while I'd suggest starting it at home first in case you need to recharge your starter battery.
I do use a fuel shut off between the engine and the tank right after shut down to keep from flooding the engine.
They don't like to restart right after a flight either. 10-15 minutes normally.
Tim
