ORIGINAL: oneup
I have a DX6 with three different different AR6000 receivers. Each receiver is separately bound to the Xmtr. The problem is that the Xmtr can still talk to any of the receivers but will use the information for the plane which is selected-hence if you are tuned to your Pitts and flying a Cularis-well you can see where I'm going. My question is this: will a DX6i only recognize the receiver it is tuned to?
Jim
Model Match
The reciever will only link up when the model memory that it's bound to is selected. If you bind it to your Pitts in Model1, and to your Cularis in Model2, it wont link up with the Pitts unless Model1 is selected.
For clarity, binding is the process of forcing the receiver to memorize the ID code of the transmitter by the use of a bind plug on the receiver and bind mode on the transmitter.
Linking is the process of turning the transmitter on, reciever on, and establishing an RF link to go flying.
