ORIGINAL: 4u2nv-RCU
Wouldn't an added manuever make all the maneuvers after it out of sequence? Aren't the sequences called that due to having to fly the manuevers in sequence? A hard A** interpretation would make all the maneuvers after the roll zeros. Adding an element to a maneuver zeros the maneuver adding a manuever makes the rest out of sequence. I may actually drag out my rule book!!LOL
As I understand the rules in AMA pattern, passing in front of the judges is the criteria as to when a maneuver is to be done. Doing multiple things at the end of the box is all still part of one turnaround until you actually set up and approach center for the next centered maneuver. This is obviously up to interpretation because it is not a black and white rule, but my interpretation is what I glean from the rules as the intent.
