modeltronics -
Were hatt actually the band plan, then I would agree, but it isn't . . . RC is still clearly designated on the *actual* band plan, found at
http://www.arrl.org/band-plan-1. Much to my surprise, the 53MHz channels are also still declared as well:
For sharing arrangements, see Section 97.303 of the FCC Rules. For detailed packet frequencies, see March 1988, page 51. Follow this link for phone patch, autopatch and HF/VHF/UHF operating guidelines. Also check out our "Considerate Operator's Frequency Guide"
160 Meters (1.8-2.0 MHz):
1.800 - 2.000 CW
1.800 - 1.810 Digital Modes
1.810 CW QRP
1.843-2.000 SSB, SSTV and other wideband modes
1.910 SSB QRP
1.995 - 2.000 Experimental
1.999 - 2.000 Beacons
80 Meters (3.5-4.0 MHz):
3.590 RTTY/Data DX
3.570-3.600 RTTY/Data
3.790-3.800 DX window
3.845 SSTV
3.885 AM calling frequency
40 Meters (7.0-7.3 MHz):
7.040 RTTY/Data DX
7.080-7.125 RTTY/Data
7.171 SSTV
7.290 AM calling frequency
30 Meters (10.1-10.15 MHz):
10.130-10.140 RTTY
10.140-10.150 Packet
20 Meters (14.0-14.35 MHz):
14.070-14.095 RTTY
14.095-14.0995 Packet
14.100 NCDXF Beacons
14.1005-14.112 Packet
14.230 SSTV
14.286 AM calling frequency
17 Meters (18.068-18.168 MHz):
18.100-18.105 RTTY
18.105-18.110 Packet
15 Meters (21.0-21.45 MHz):
21.070-21.110 RTTY/Data
21.340 SSTV
12 Meters (24.89-24.99 MHz):
24.920-24.925 RTTY
24.925-24.930 Packet
10 Meters (28-29.7 MHz):
28.000-28.070 CW
28.070-28.150 RTTY
28.150-28.190 CW
28.200-28.300 Beacons
28.300-29.300 Phone
28.680 SSTV
29.000-29.200 AM
29.300-29.510 Satellite Downlinks
29.520-29.590 Repeater Inputs
29.600 FM Simplex
29.610-29.700 Repeater Outputs
6 Meters (50-54 MHz):
50.0-50.1 CW, beacons
50.060-50.080 beacon subband
50.1-50.3 SSB, CW
50.10-50.125 DX window
50.125 SSB calling
50.3-50.6 All modes
50.6-50.8 Nonvoice communications
50.62 Digital (packet) calling
50.8-51.0 Radio remote control (20-kHz channels)
51.0-51.1 Pacific DX window
51.12-51.48 Repeater inputs (19 channels)
51.12-51.18 Digital repeater inputs
51.5-51.6
Simplex (six channels)
51.62-51.98 Repeater outputs (19 channels)
51.62-51.68 Digital repeater outputs
52.0-52.48 Repeater inputs (except as noted; 23 channels)
52.02, 52.04 FM simplex
52.2 TEST PAIR (input)
52.5-52.98 Repeater output (except as noted; 23 channels)
52.525 Primary FM simplex
52.54 Secondary FM simplex
52.7 TEST PAIR (output)
53.0-53.48 Repeater inputs (except as noted; 19 channels)
53.0 Remote base FM simplex
53.02 Simplex
53.1, 53.2, 53.3, 53.4 Radio remote control
53.5-53.98 Repeater outputs (except as noted; 19 channels)
53.5, 53.6, 53.7, 53.8 Radio remote control
53.52, 53.9 Simplex
2 Meters (144-148 MHz):
144.00-144.05 EME (CW)
144.05-144.10 General CW and weak signals
144.10-144.20 EME and weak-signal SSB
144.200 National calling frequency
144.200-144.275 General SSB operation
144.275-144.300 Propagation beacons
144.30-144.50 New OSCAR subband
144.50-144.60 Linear translator inputs
144.60-144.90 FM repeater inputs
144.90-145.10 Weak signal and FM simplex (145.01,03,05,07,09 are widely used for packet)
145.10-145.20 Linear translator outputs
145.20-145.50 FM repeater outputs
145.50-145.80 Miscellaneous and experimental modes
145.80-146.00 OSCAR subband
146.01-146.37 Repeater inputs
146.40-146.58 Simplex
146.52 National Simplex Calling Frequency
146.61-146.97 Repeater outputs
147.00-147.39 Repeater outputs
147.42-147.57 Simplex
147.60-147.99 Repeater inputs
Notes: The frequency 146.40 MHz is used in some areas as a repeater input. This band plan has been proposed by the ARRL VHF-UHF Advisory Committee.
1.25 Meters (222-225 MHz):
222.0-222.150 Weak-signal modes
222.0-222.025 EME
222.05-222.06 Propagation beacons
222.1 SSB & CW calling frequency
222.10-222.15 Weak-signal CW & SSB
222.15-222.25 Local coordinator's option; weak signal, ACSB, repeater inputs, control
222.25-223.38 FM repeater inputs only
223.40-223.52 FM simplex
223.52-223.64 Digital, packet
223.64-223.70 Links, control
223.71-223.85 Local coordinator's option; FM simplex, packet, repeater outputs
223.85-224.98 Repeater outputs only
Note: The 222 MHz band plan was adopted by the ARRL Board of Directors in July 1991.
70 Centimeters (420-450 MHz):
420.00-426.00 ATV repeater or simplex with 421.25 MHz video carrier control links and experimental
426.00-432.00 ATV simplex with 427.250-MHz video carrier frequency
432.00-432.07 EME (Earth-Moon-Earth)
432.07-432.10 Weak-signal CW
432.10 70-cm calling frequency
432.10-432.30 Mixed-mode and weak-signal work
432.30-432.40 Propagation beacons
432.40-433.00 Mixed-mode and weak-signal work
433.00-435.00 Auxiliary/repeater links
435.00-438.00 Satellite only (internationally)
438.00-444.00 ATV repeater input with 439.250-MHz video carrier frequency and repeater links
442.00-445.00 Repeater inputs and outputs (local option)
445.00-447.00 Shared by auxiliary and control links, repeaters and simplex (local option)
446.00 National simplex frequency
447.00-450.00 Repeater inputs and outputs (local option)
33 Centimeters (902-928 MHz):
902.0-903.0 Narrow-bandwidth, weak-signal communications
902.0-902.8 SSTV, FAX, ACSSB, experimental
902.1 Weak-signal calling frequency
902.8-903.0 Reserved for EME, CW expansion
903.1 Alternate calling frequency
903.0-906.0 Digital communications
906-909 FM repeater inputs
909-915 ATV
915-918 Digital communications
918-921 FM repeater outputs
921-927 ATV
927-928 FM simplex and links
Note: The 902 MHz band plan was adopted by the ARRL Board of Directors in July 1989
23 Centimeters (1240-1300 MHz):
1240-1246 ATV #1
1246-1248 Narrow-bandwidth FM point-to-point links and digital, duplex with 1258-1260.
1248-1258 Digital Communications
1252-1258 ATV #2
1258-1260 Narrow-bandwidth FM point-to-point links digital, duplexed with 1246-1252
1260-1270 Satellite uplinks, reference WARC '79
1260-1270 Wide-bandwidth experimental, simplex ATV
1270-1276 Repeater inputs, FM and linear, paired with 1282-1288, 239 pairs every 25 kHz, e.g. 1270.025, .050, etc.
1271-1283 Non-coordinated test pair
1276-1282 ATV #3
1282-1288 Repeater outputs, paired with 1270-1276
1288-1294 Wide-bandwidth experimental, simplex ATV
1294-1295 Narrow-bandwidth FM simplex services, 25-kHz channels
1294.5 National FM simplex calling frequency
1295-1297 Narrow bandwidth weak-signal communications (no FM)
1295.0-1295.8 SSTV, FAX, ACSSB, experimental
1295.8-1296.0 Reserved for EME, CW expansion
1296.00-1296.05 EME-exclusive
1296.07-1296.08 CW beacons
1296.1 CW, SSB calling frequency
1296.4-1296.6 Crossband linear translator input
1296.6-1296.8 Crossband linear translator output
1296.8-1297.0 Experimental beacons (exclusive)
1297-1300 Digital Communications
2300-2310 and 2390-2450 MHz:
2300.0-2303.0 High-rate data
2303.0-2303.5 Packet
2303.5-2303.8 TTY packet
2303.9-2303.9 Packet, TTY, CW, EME
2303.9-2304.1 CW, EME
2304.1 Calling frequency
2304.1-2304.2 CW, EME, SSB
2304.2-2304.3 SSB, SSTV, FAX, Packet AM, Amtor
2304.30-2304.32 Propagation beacon network
2304.32-2304.40 General propagation beacons
2304.4-2304.5 SSB, SSTV, ACSSB, FAX, Packet AM, Amtor experimental
2304.5-2304.7 Crossband linear translator input
2304.7-2304.9 Crossband linear translator output
2304.9-2305.0 Experimental beacons
2305.0-2305.2 FM simplex (25 kHz spacing)
2305.20 FM simplex calling frequency
2305.2-2306.0 FM simplex (25 kHz spacing)
2306.0-2309.0 FM Repeaters (25 kHz) input
2309.0-2310.0 Control and auxiliary links
2390.0-2396.0 Fast-scan TV
2396.0-2399.0 High-rate data
2399.0-2399.5 Packet
2399.5-2400.0 Control and auxiliary links
2400.0-2403.0 Satellite
2403.0-2408.0 Satellite high-rate data
2408.0-2410.0 Satellite
2410.0-2413.0 FM repeaters (25 kHz) output
2413.0-2418.0 High-rate data
2418.0-2430.0 Fast-scan TV
2430.0-2433.0 Satellite
2433.0-2438.0 Satellite high-rate data
2438.0-2450.0 WB FM, FSTV, FMTV, SS experimental
Note: The 2300 MHz band plan was adopted by the ARRL Board of Directors in January 1991
Note: The following band plans were adopted by the ARRL Board of Directors in July 1988
3300-3500 MHz:
3456.3-3456.4 Propagation beacons
5650-5925 MHz:
5760.3-5760.4 Propagation beacons
10.00-10.50 GHz:
10.368 Narrow band calling frequency 10.3683-10.3684 Propagation beacons
10.3640 Calling frequency
