RCU Forums - View Single Post - GP Waco?
Thread: GP Waco?
Old 06-15-2011 | 07:11 AM
  #689
skillet92
Default RE: GP Waco?
I used 2 y harnesses. I mixed the aileron channel with the gear channel. I then put one y harness on the top wing and just put the one wire out. I ran a y harness from the aileron to the bottom wings servo wires and a 12" servo extension from the gear channel out to the top wing. That way I only have one wire that can be seen. Remember correctly I had to change one of the channels direction in the mix function so that they would all go the way the needed to. I can check when I get home tonight if you want.
