DLE 20 carb
I've got 2 DLE 20's that were purchased from different sources. One from Troy Built and one from Virginia Model Builders. Be advised to check warranty proceedures before purchasing an engine. VMB does not do any warranty work, I was refered to their supplier, Laser Hobbies. Undoubtedly they don't do any work either and just return item to China. The carb on the one from VMB leaks fuel from around the needles, idles rich with the low speed run all the way to the stop. I sent it to Laser Hobbies, and after 2 weeks, they said yes, it was a bad carb and they are about ship it out. (I guess they mean back to China) Been almost 2 more weeks and nothing.
Can anyone tell me what Walbro Carb will work on this engine? Right now all I can do is compare venture size and bolt pattern.
