RE: 3 x DLE 30's - cranky
There are five DLE30's at my field and most all ran real crappy before the stock plug was changed and since then all except one is running fine. The troublesome one would run great one minute and not the next. It starts easily and has a great idle and mid range but sputters badly on occassion and will die if WOT is attempted. After several carb teardowns and thorough cleanings it is running as it should so hopefully the problem has been solved.
Karol
