RCU Forums - View Single Post - e-Neptuno
Thread: e-Neptuno
Old 06-22-2011 | 09:15 AM
  #91
roalddogge
Default RE: e-Neptuno
Hi Chris,
If you want to reduce some weight then maybe you should removed that boat achor of a Q80 and use it for it's intended purpose....;-)
I got one to install but never did when I found out that the actual weight was more than 670 grams, even without the rear support. Little bit more than the advertised 630 grams (or the 610 grams advertised at that time). I never found such a big deviation with other manufacturers. Also the later 20 poles version was much heavier than advertised :-(
Roald
