RCU Forums - View Single Post - Help finding DA50 needle settings
Old 08-16-2003 | 01:53 PM
Paul Cataldo
My Feedback: (10)
Default Help finding DA50 needle settings
Ok guys,
I have checked all the fuel lines. No problems there. Like I said, I have a 6 volt pack w/new Cermark HD switch on IGN. I really have no way of checking the battery under load right now, but I will see if someone can help with that.
When I flip the prop to check for spark. I do see a little blue spark, but it doesn't seem that it is much of a spark to me. Again, something I'm not too sure about.
It took me 10 minutes to get it to run. Same thing happened. It would fire and run for about 1 second and die. It did this about 10 times, and then it finally ran. However, I was trying to set the needles, and when I tried to transition from idle to full throttle, the engine would hesitate to transition. I then put it back at idle, and the engine just died. Can't get it to restart. My fingers have blisters on them from the prop.
P.S. This engine just came back from DA to get a check up from a prop strike. Everything was fine, and DA test ran the engine. However, I did not send the IGN in, because it wasn't necessary.
