RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 06-25-2011 | 08:43 AM
  #6154
vertical grimmace's Avatar
vertical grimmace
Default RE: DL-50 engine
ORIGINAL: Craig 01
Hi Greg,
If your using a known good plug and your problems have only recently started,which it sounds they have,check the carb regulating diaphragm is soft/supple and not deformed/stiff,whilst your at it check the pump diaphragm and flap valves are supple and not deformed as well.
Craig
Not really a reason to. Most have moved on to the DLE 55.
