RCU Forums - View Single Post - Dope and Fabric Finish
Old 06-29-2011 | 01:55 AM
TomCrump's Avatar
TomCrump
Default RE: Dope and Fabric Finish
On my Spacewalker, I used Solartex. The weave was filled, in the same area as you have in primer, with epoxy finishing resin.
By spraying 3 color coats, using no primer, I found the weave to be nearly filled. In areas where the trim color was added, (3 more coats) the weave was completely filled.
You may find that Solartex will be an easer solution to your problem
ID:	1629144   Click image for larger version
ID:	1629145   Click image for larger version
ID:	1629146   Click image for larger version
ID:	1629147   Click image for larger version
ID:	1629148   Click image for larger version
ID:	1629149   Click image for larger version
ID:	1629150   Click image for larger version
