ORIGINAL: Jjet
I'm trying to figure out how to program this valve with the card. It's written in german/ english. I want simply to have function gear up & doors close later in flight doors open (stay open) and gear down. Also program brake function program. Thanks much.
1. What you need to do is first plug a battery into the programing card, each time you make a selection a led will stay lit when you hit enter
2. press the enter button till you are in the mode selection section and select mode 1
3. press the enter button now set the function to gear
4. press the enter button and set v1
5. press enter and set valve to nor/on
6. press enter and use the arrow keys to set your delay (3 to 5 seconds has always worked)
7. plug you ev5u into the programming card and a blue light will start to blink 5 times indicating that you have a connection and it has completed uploading your perameters.
you are now done and can test the valve.
Alan
