RCU Forums - View Single Post - canard foreplane loading..??
Old 06-30-2011 | 12:50 PM
canardlover's Avatar
canardlover
Default RE: canard foreplane loading..??
Hi guys, thanks a lot for sharing your plans and viewpoints but now is vacation time and I leave home tomorrow morning and will be out for 2-3 weeks. So do not expect any more Load factors until I´m back.
Meanwhile you can "chew" on some load factors for published designs that I have calculated as follows:
Gannet, .40 pusher, low wing RCM, Sept-83 Lf=142 %
Dragon, .40 pusher, shoulder wing RCM, May-79 Lf=156 %
Sweepee, .40 tractor FSW, low wing MA, Aug-89 Lf=172%
Basic Canard, .40 pusher, low wing, twin fin MAN, Jan-85 Lf=188 %
Scat Twin.40 push pull .40-.46, low wing RCM, July-89 Lf=227 %
Quite a span with you Villa on the “low end” at 110% and the Scat Twin at a whopping 227%. I have an article in RCMW Nov. 2001 stating that the Scat Twin “…needs 10 degrees nose up elevator for level flight.” Not surprising at that Load factor.
Cheers for now../Harald
