RCU Forums - View Single Post - The AMA EC needs to move on this.
Old 07-05-2011 | 09:48 AM
ctrout
Default RE: The AMA EC needs to move on this.
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="FONT-FAMILY: Arial; FONT-SIZE: 9pt">If this forum is helping you understand the AMA and you don’t spend much time talking within your club or talking with any of the other side of the fence I can understand completely why you feel this way. And why they are here to help you understand what they do here.  Why the forums at the AMA are all but dead.
Why would 6 guys spend every minute to talk about what they think year after year and the other 2000 in the AMA forum give up?
For the areas they did help, you will not hear much about all the others.
What works or did not work the first time it was tried or why its not a good idea to do it in the first place.
In here you will only see why it needs to change.
Most of us will spend time learning from as many as we can before making a change not decide we know best.
Most need proof that the values in what he believes from past history but you will only know what they tell you if you don’t look around. Now that most posts with any value have a short life spans from the same 6 users you will not see much.
if what you see here was as it seems why would the other 2000 users all the staff and all the mods be fed up with only the 6 or so that do this in the forums every day.
If you’re going to get a job in the AMA SO YOU CAN RIP IT APART AND FIX IT FROM THE INSIDE what would happen if you’re wrong. And what you change damages it. Will you be responsible for what you did?
</p></span></p><p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><span style="FONT-FAMILY: Arial; FONT-SIZE: 9pt">Or just start up another AMA type Org.?
</p></span></p><p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font face="Times New Roman" size="3">What you looking at now is why did a AMA member just decide to leave because hes reading what you all are talking about from only your point of view.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font face="Times New Roman" size="3">You’re now solely reasonable for a member giving up on the AMA </font></p><p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font face="Times New Roman" size="3">WAY TO GO!</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font size="3"><font face="Times New Roman"><span style="mso-spacerun: yes"> </span><span style="mso-spacerun: yes"> </span><span style="mso-spacerun: yes"> </span><span style="mso-spacerun: yes"> </span></font></font></p>
