Please need help with my minimag
Hello,
Please, I need some help here. I am new in this hobby and I am not sure what to do.
I just got a multiplex mini mag two weeks ago. I just finished upgrading the motor. I got the power pack recommended by multiplex USA. I also got a esc 36 amp by castle and I am using a prop 6x4. (I did some research before doing so.) I tried to fly it today. And before heading to the park, I did some sort of pre check. I turned the tx on. I plugged the battery in. Performed the binding process and right after that, I noticed that the motor, ailerons, rudder and elevator started moving by themselves without using the tx. It lasted for a few seconds. It was so weird. I unplugged the battery and turned off the tx. Waited for a few minutes. I turned tx back on and plugged the battery in and it happened again. All the servos keep twitching all the time. Not sure if that is normal.
I would like to know if I am doing something wrong before sending it back to the company.
Am I missing something???
Please, any comments or advise would be great.
Thank you.
