RCU Forums - View Single Post - Having trouble installing throttle servo, Help needed
Old 07-07-2011 | 11:15 PM
Boomerang1's Avatar
Boomerang1
Default RE: Having trouble installing throttle servo, Help needed
What you may have to do is run the throttle linkage against the fuselage side & angle the linkage across after the firewall.
99% of model engines don't have a spring return on the throttle. The cable Huck mentions has an inner cable & an outer sleeve & is quite stiff & will pull as well as push. I find cables, either wire type or plastic type (known as snakes or Gold N Rods), the easiest for throttle linkages. - John.
