RE: HTML code in classified descriptions
The Full Editor is the default selection. You do not have to change anything in order for this issue to occur in your ads.
If you change the editor to the Basic version, you can clean up your ad and avoid the problem until we can get the tools fixed. You must however manually remove all of the tags when you are in the Basic version in order for this to work.
