Q-75 or 3W 75?
I will be needing more pull out of a hover and less forward speed. So I will probably stay in the 6 to 8 pitch on the prop. I have a BME 102 motor for my 31% CA 300L but it doesn't fit in the cowl. They recomend a 3W 75 and I have a Quadra 75. I just don't know how much power I will loose if I use the Quadra. Weight is about the same on both motors if I use the Quadra B model and I need about a 5 pound engine for balance. Thanks.
Steve
